- HuntindogExplorerWhat is boils down to is how bad do you want AC?
As tempertures go up, so does the AC current draw, and at the same time the generator loses power with higher temps. So a "test" in the driveway really means nothing. If you go with a 2000, then it may some day not work for you when you REALLY want it to. - pianotunaNomad IIIHi,
If you get a Hybrid inverter then a 2k generator will run the air conditioner just fine and you can use eco mode. - TomG2ExplorerMine generally use 10-11 amps when operating in hot weather at 1,000 ft elevation with other things turned off. That will not destroy the Honda 2000.
- xteacherExplorerTwo Hondas in parallel will give you enough power, and they're lighter to carry (each separately, of course), than one bigger generator.
- TNRIVERSIDEExplorer
RamRider wrote:
My Honda Companion just arrived this week, I used the wiring kit and plug adaptor and the ac fired right up with no issues or overload warnings. Using just one Honda 2000 will over load the generator.
Using just one gen should not overload the gen. Honda generators have an overload protection circuit built in. Honda says not to continue an operation the repedly trips the overload protection. If it works like mine does I feel its fine to use it. Read the manual. - Jayco23FBExplorer
Rainier wrote:
Mostly likely not. I have two 2000 yamaha generators that I connect to each other for a total of 4000w to run my TT A/C and other systems.
X2 .. I also installed a hard start kit that helped alot. - Mr_BeeboExplorerMy Champion 2000s are 1700 watts continuous. I have had it kick the ac on, but I use two. I have owned Hondas and loved them, but I also loved buying two Champions for the price of one Honda.
- TomG2ExplorerWhile there are other, and perhaps better, options, I have been using a Honda 2000 to run 13.5k air conditioners on several different trailers over the last ten years. No harm to Honda, as they have built in safeguards. One does have to manage other demands, like converter, refrigerator, etc.
I mostly use mine for quick cool downs while traveling and don't demand 24/7 100% duty cycles. - RamRiderExplorerMy Honda Companion just arrived this week, I used the wiring kit and plug adaptor and the ac fired right up with no issues or overload warnings. Using just one Honda 2000 will over load the generator.
- TNRIVERSIDEExplorerIt can work. I hooked my Honda 2000I gen up to the camper yesterday to see if it would run the AC unit and it does. 13,500 btu unit. I turn it on with the thermostat set to a warm setting so only the fan is running then lower the thermostat to a cooler setting. This allows the gen to have the fan running then bring on the compressor. I get a very brief low voltage light but the gen and AC unit work together. This is my experience. Not hearsay.
44,052 PostsLatest Activity: Nov 23, 2025
