Skibane
Aug 11, 2022Explorer II
According to a quick internet search, the advertised "dry" weight of the 201 BHXL is around 4200 pounds.
The advertised "dry" weight is almost always less than the actual "dry" weight.
By the time you add any optional equipment on your particular trailer, fill the propane and fresh water tanks, and then add the stuff you and your passengers will be bringing - You're probably going to be right at the 5000 lb. tow rating of your Ridgeline.
Not recommended.
Not recommended.
