JimK-NY
Jul 28, 2020Explorer II
I have no problem using my Honda 2000i in a compartment. The compartment was designed for use with a generator. It is sealed from the rest of the camper. There is a side door which must be latched open when in use. The rear door has a screen and can be closed even in use.
I did need to cut a piece of plywood and put on some edges to serve as a tray. I pull the generator partly out of the compartment for starting or adding fuel.
44,066 PostsLatest Activity: Apr 16, 2026
