Bert_the_Welder
Jul 28, 2020Explorer II
JimK-NY wrote:
I have no problem using my Honda 2000i in a compartment. The compartment was designed for use with a generator. It is sealed from the rest of the camper. There is a side door which must be latched open when in use. The rear door has a screen and can be closed even in use.
I did need to cut a piece of plywood and put on some edges to serve as a tray. I pull the generator partly out of the compartment for starting or adding fuel.
Thanks Jim.
Was the plywood try to raise the floor of the cabinet up to get it at the level of the bottom lip, allowing for ease of sliding the gen in and out? Or something else?
44,068 PostsLatest Activity: Jun 20, 2026
