Bert_the_Welder
Aug 03, 2020Explorer II
msiminoff wrote:
I installed a Honda EU2000i in my TC's generator compartment 13 years ago, and it has been quietly purring along in there ever since...
Goodby Onan, Hello Honda
Then I added a tri-fuel kit so I can run it on propane (also removed the auxiliary gasoline tank):
Onboard EU2000i... now on propane
And I went through some effort to keep noise & vibration to a minimum;
Silencing the silent
Cheers,
-Mark
Boy Mark, that's a nice job. Thank you for posting the links. They've been bookmarked for the future.
Questions, if I may:
-SS tube TIG'd onto the exhaust pipe?
-Did you find the heat coming off the TIG'd on tube melted/damaged the hole it's going through? Or did you pack it with refractory wool or??
-Are the fans plugged into the gen direct, so they kick on when the gen starts or are they powered via the house 12v and on a switch?
- Do you think lining the compartment with something like Dynamat would be worth the effort to further the sound isolation from getting inside the camper?
Again, thanks for posting!
44,068 PostsLatest Activity: Jun 20, 2026
