bmanning wrote:
transamz9 wrote:
bmanning wrote:
pnichols wrote:
Hannibal wrote:
I've said a few times over the years, if I were deaf and didn't have a tach, I couldn't tell the difference towing with the gas or diesel rigs I've owned. Diesels are stronger but, not necessarily faster. The newest ones are by a small margin as they have gobs of horsepower at lower rpm. The previous diesels as recently as ten years ago didn't have much on their gas engine counterparts. Twenty years ago they had nothing on them. I owned one. 160 hp doesn't get much work done with even a light TT against any wind at all. All that torque (400 ft/lbs) and it couldn't apply it above 2500rpm so O/D was the only option at hw speeds. That meant 400 ft/lbs X .69 = 276 ft/lbs to the drive shaft. It was pathetic. Flywheel torque is just the beginning. It's what's at the rear axle that counts. Just the same, every one of my trucks has made me happy!
X1000 ... outstanding comments!
Finally, an island of sanity in the diesel-versus-gas sea of chaos. :C
Hannibal has owned both, has great insight, and I love to reference him when the simpletons start declaring "if you've ever towed with a diesel you'd never want to drive a gasser again."
I have owned both and tow with both every week.I will take a whole lot for me to ever go back to a gas TV. The thing with Hannibal is that if you look at his list of TV's he never compares apples to apples. Going from an 03 Cummins SO to an 05 Hemi. Then from an 05 Hemi to a 2010 Ford.
If he could compare a 05 Hemi to a 05 Cummins then he probably wouldn't think the same about the Hemi. Same with the 2010 5.4 gas compared to a 2010 Diesel. Our newest addition to our fleet is a 2012 6.2 Ford and the is no comparison to the 2012 diesels. Will the gas tow as fast as the diesels? Yes they will. Hp is Hp. Do they do it as easily? NO WAY
We can certainly agree to disagree, but is there that much difference between an 03 CTD & an 05 CTD? If Hannibal had an 01 or 02 with the old fuel delivery system I'd agree.
You've posted before about the Ford 6.2L you use for work, and I still say if it's as bad as you say to get that thing to a dealer to get looked at. Many, many happy 6.2L owners out there, some of whom came from diesel and are quite pleased with the 6.2L V8's performance.
There is quite a bit difference between the SO 03 he had and an 05 Cummins. As far as the 6.2 here at work, it runs fine when not hooked to something which is about 90% of the time but when it gets hooked to a tool trailer and has 4 guys and there personal tools in it then it becomes a constant screamer. Out on the road where you can lock it into a gear it's not as noticeable but it is still loud running in the lower gears but when you are driving in stop and go traffic in Lexington and Louisville loaded, it is sick. We also have an 01 F350 service truck with the 5.4 in it and it will scare the heck out of you on the interstate when it gears down out of OD on the slightest bit of incline. This is with nothing hooked to it. I quit running it on cruise just so I will know when to expect the sudden scream for mercy when it comes out of OD. When my 6.0 went down ( I know, never would have thunk it)I drove this service truck for a couple days and I never thought I would say it but I was so glad to have my 6.0 Powernothing back.;)
