transamz9 wrote:
wilber1 wrote:
transamz9 wrote:
wilber1 wrote:
transamz9 wrote:
wilber1 wrote:
Problem with these threads is they always become gas versus diesel debates instead of boosted versus unboosted. Futile.
Okay,put a boosted eco boost into a HD truck with the same boosted hp diesel. Hook up the max trailer weight to the back of it.
As soon as they put a 6.7 liter turbocharged direct injection gas engine in a HD truck, let's do that. Until then, stop comparing a 3.5L gasser to a 6.7 liter diesel.
LOL! You will never see a 6.7 liter turbo gas in a truck. HAHA, we couldn't afford to keep gas in it. We are comparing hp to hp not liter to liter.
It would likely be a fuel hog but it would be a towing monster. However, as you say we are comparing hp to hp, not fuel economy. If you are comparing hp to hp how can you not compare liter to liter? My ten liter boosted engine is more powerful than your five liter boosted engine. Duh!
The OP was talking about hp v/s hp not liter v/s liter.
Depends on what you consider a towing monster is. It's still going to have to rev very high to be into the hp range.It's hard to get air forced into a gas motor because of the nature of the fuel and how it reacts. A diesel motor is different because of the fuel used. The more fuel and air the more power until you blow it apart. You start blowing holes in pistons in a gas motor from detonation once you start raising cylinder pressures or run fuel that you can't pump from a fuel island.
There have been turbo gas motors around for decades and some were put in small trucks with no tow rating. There are reasons for this. The Chevy cyclone is a good example. Why didn't GM put that motor into a 1/2 ton pick up? I think it was 300/300 back in 1990 and the S10 it was in would out run a Vette stock to stock.
I'm not taking sides in the diesel versus gas debate. I have a turbo direct injection gas engine in a car and a turbo diesel in my truck.
Both have their pros and cons, I think diesels are better suited to towing and clear winners on fuel economy, but when it comes to power output, it is possible for gassers to be superior with today's technology.
Some numbers for you.
Audi 2.0t direct injection turbo on 91 octane. Take some other manufacturer's 2L DI turbo gassers and you will find similar or even better numbers.
HP 220 at 4450 to 6000 RPM.
110 hp per liter displacement
Torque 258 lb ft 1500 to 4300 RPM.
129 lb ft per liter displacement
Cummins HO
HP 385 at 2800 RPM.
57.4 hp per liter displacement
Torque 850 at 1700 RPM.
126 lb ft per liter
When it comes to torque per liter, it is a dead heat but the gasser peaks at a lower RPM and is flat over a 2800 rpm range. So much for the diesel's low RPM torque advantage.
When it comes to HP per liter, it is not even close. But you say, the gasser hits peak HP at a much higher RPM. True, but if you calculate the gassers HP at the diesel's peak of 2800 RPM it comes to
68.5 hp per liter for the gasser vs
57.5 hp per liter for the diesel, the gasser still wins.
Granted the smaller engine will have less HP loss due to friction and there is less mass moving around so it should be a bit more efficient, so lets compare likes with likes when it comes to size.
Audi's own 2.0 Turbo diesel
HP 140 at 4000 RPM.
70 HP per liter
Torque 236 lb ft 1750 to 2500 RPM.
118 lb ft per liter
Again, when it comes to HP and torque, the gasser clearly wins. Fuel economy, that's something else again. Diesel hands down.
That's comparing HP to HP.
