handye9 wrote:
bobndot wrote:
Not to say it doesn't exist , I have never seen a petcock on the tank end . Hopefully El Camino Man will sign back on to explain better so we be a better help . At this point we are guessing .
I have a 2000 Maverick and my brother has a 92 Shadow Cruiser, both, were built with a petcock at the tank and the drain tube goes straight out the bottom of the TC. Not a good setup when you want to drain your tank without unloading the camper. I modded mine to drain out the back.
El Camino Man: Your drain out the back, was probably done for this reason. Keep truck bed dry while draining the tank.
Tnx. for the info. Now that you said that, i remember someone having a drain issue where it poured onto the trucks beds and he had to re-route the line.
Like you said, not the best idea . Doing what you did was a much better idea .
El Camino Man , looks you found the fix, Pics are the way to go , there are so many configurations and home made fixes out there .
Good to see you are able to make the repair .
While you are doing this , it might be a good idea to drill an access port in order to get your to the inside of your tank to clean it as well as assist you in making the new valve/line install an easier one . scroll thru the pics
water tank deck plate
