buck2's avatar
buck2
Hot skin issue please help
Hi, I have a 1996 30 ft camper I'm having a hot skin issue where 50 v is leaking from shell of camper to ground. Each of the six breakers I have on my camper reduce this voltage as I shut each of them off( each drops hot skin voltage about 8-10 volts) and eventually when I have all the breakers off besides the main the breaker the voltage drops to 1volt. I also get increasingly more voltage up to the 50 volt hot skin issue when touching my volt meter between separate neutral bar and separate ground bar in electric panel ( each breaker I turn on increases voltage between ground bar a neutral bar 8-10 volts. How do I isolate what is causing this problem if all breakers are leaking voltage. Thanks
  • You definitely have a open ground, as suggested get a voltmeter and start at receptacle the RV is plugged into. Harbor Freight has a coupon for a free voltmeter with any purchase, I got another one yesterday. :) Can't ever have too many voltmeters.
  • Trip your GFCI receptacles and check with meter to see if problem goes away. It could be a defective GFCI.
  • To be more specific I should add that when I'm testing the hot skin issue I'm touching the voltmeter from the camper siding to the dirt . Also I do have a circuit tester and it seems the outlets are wired properly. Also I do have it hooked into a normal 15 amp house plug to 30 amp adapter
  • Are you sure the outlet you are plugged into is grounded? I would buy a ckt tester from Home Depot or Harbr Freight that checks proper grounding. They cost about $5 & and well worth the money. First check the outlet you are plugged into for grounds.
  • You have a bad ground in the shore power.
    Are you using an adapter? try another one.
    Get one of the small receptacle plug in tester.
  • You shouldn't read voltage between ground and neutral. I would think you have a problem with the power cord or power supply that your plugged into. Sounds like you are missing a neutral. Be cautious you could get electrocuted if it is a ground issue. I would call an electrician to check it out and unplug it in the meantime.
