jacko147
Mar 22, 2016Explorer
Mark and Linda wrote:
I was de winterizing my Puma today...I noticed one of my bypass valves at the hot water heater leaking. I have it out, would anyone know of a good place to get a replacement valve? I have been trying to research the numbers on the valve that I removed. Any suggestions will be appreciated.
Any 90 degree valve should work, I notice your puma is a 2009 so you'll most likely need to use a shark bite fitting or you'll need some pex clamps and a pex crimper, regular hose clamps will leak.... I'm guessing this is the bottom valve going to your hot water heater?
