mackenziejk's avatar
mackenziejk
Hot water heater drain plug leaking
Hi i have a 2005 areolite 215 cub, and when i put water in my trailer, it starts to leak at the drain plug, i have replaced it and put the tape on it and still leaks, when water is in the water heater, i have no idea on how to get it to stop, this is my first year with the camper.
  • Pick up a 1/2" pipe nipple from your hardware store......
    Screw it into the drain hole.....easy goes it---screw it in a little then back it out then in/back etc. (chasing the threads) tank is aluminum and the pipe nipple is steel so it will clean up the threads.
    Then get a new 'nylon' plug.....they come two to a pack
    Screw new plug in hand tight then snug up with a wrench.
    Fill tank/check for leak/heat water /check for leak.
  • "plastic bolt". That means you have an Atwood water heater. Go to your local RV parts dealer such as Camping World and get a new plug. In fact, get a spare too. I'm guessing that a new plug will solve your leak issue.
  • Would caulking the end of the plastic bolt work? I just have no idea how to chase a thread
  • The previous owner may have buggered up the threads. Given your description I would try chasing the threads to put them back to normal so the plastic plug seats as designed
