Atlee
Nov 05, 2018Explorer II
That's one of the dumbest things I've ever heard. A water heater that both electric and propane, yet you must go outside to switch on the electric.
If it's a "feature" of a Suburban brand, those people are stupid as rocks.
SoundGuy wrote:bob2194 wrote:
The hot water heater is both electric and propane. I only have one switch. My older TT had 2 switches, this one has only one one and its electric, off and its propane.
If you have a gas / electric water heater with only one switch inside the trailer then it's a Suburban SW6DE whereas your previous water heater with 2 switches inside the trailer was an Atwood. That one inside switch when switched on means the water heater is running on gas, the switch that turns on the electric heating element is on the water heater itself, accessed by opening the outside water heater hatch. It's a rocker switch with a pin through it so you don't inadvertently turn the electric element on when there's no water in the tank - do that and you'll instantly burn out the element.
