drsteve
Nov 05, 2018Explorer
SoundGuy wrote:bob2194 wrote:
The hot water heater is both electric and propane. I only have one switch. My older TT had 2 switches, this one has only one one and its electric, off and its propane.SoundGuy wrote:
If you have a gas / electric water heater with only one switch inside the trailer then it's a Suburban SW6DE whereas your previous water heater with 2 switches inside the trailer was an Atwood.Ralph Cramden wrote:
With a pin through it? That's a new one here, as I have had 3 Dometics and none had a pin through the outside switch for electric operation.
Read my post again - I said if you have a water heater with 2 switches inside the rig then it's most likely an Atwood. If there's just 1 switch located inside and it is a gas water heater with an electric heating element option then it's a Suburban with the electric switch located on the water heater itself, and yes Virginia there is a pin through it to prevent accidentally turning on this switch when there's no water in the tank. Here's a pic ...
In some cases a trailer manufacturer may take it upon themselves to install a 2nd switch inside the rig in parallel with this tank mounted switch. Most don't, K-Z being one, so I added my own switch to my K-Z Spree 240BH-LX ...
For those who still doubt that Suburban water heaters have a switch on the unit itself for activating the electric heating option even though the pic above clearly shows that it does :S here's a discussion about this very issue.
My Suburban 2017 vintage WH has the electric element
switch outside, but no pin and no provision for one.
