Camper_Jeff___K's avatar
Oct 12, 2022
Hot Water Recirculation Loop - Save Water - Camp Longer
A Great Truck Camper / RV Modification
How to Install A Hot Water Recirculation Loop Or Recovery Loop
Save Fresh Water And Extend Your Camping Trip A Day Or Two With Water Saved By Not Running It Down The Drain While Waiting For Hot Water To Arrive At The Faucet
VIDEO Hot Water Recirculation Loop VIDEO
Valve and switch
Return Loop into Fresh tank
Return Loop from kitchen sink Hot, to solenoid valve then back into fresh tank.
  • 3 tons wrote:
    Bravo Jeff, that is truly a most logical and creative idea Sir, saving precious water while conserving gray tank space all in one fell swoop - Yea!! :C
    What is the source and model of the solenoid valve??
    3 tons
    Valve is "US Solid" half inch stainless steel body solenoid $42.00
    Momentary push button switch with LED 10 amp rated by Apiele $16.00
    Both from AMAZON.
    Switch
  • Dave D. wrote:
    This might be useful for winter camping. Hot water won't freeze up. Although shouldn't the recirculation return to the hot water tank, not the main tank? At least this is how I plumbed my house's recirc. heat.
    The water needs to return to the low pressure side of the pump to cause a pressure drop so the pump will start. Returning to the water heater has no pressure drop because it's on the pressure side of the pump so the pump won't activate because no pressuredrophappens. You could return water to the cold Input of the water heater but to make it work, you would need a small pump and a check valve to prevent backflow. Another way to connect if you can make room is to put the return connection to the pipe between the tank and the pump. This way, there is a low pressure connection to the fresh tank and the water will recirulate directly into the intake side of the pump and get pumped right back out into the system, not into the tank
    Yup. Did this years ago to prevent further freeze ups.
    Mine is a small 1 amp DC pump that pumps water to a grundfos temperature regulated valve made for home circulating systems.
    Manual switch or if cold the pump will cycle on with the furnace. Mine uses the cold side as the return so it gets some heat too.
  • 3_tons's avatar
    3_tons
    Explorer III
    3 tons
  • This might be useful for winter camping. Hot water won't freeze up. Although shouldn't the recirculation return to the hot water tank, not the main tank? At least this is how I plumbed my house's recirc. heat.
  • JRscooby wrote:
    LOL. I use a bucket to catch the water you are saving.
    My way is way cooler than a bucket and I don't have to screw around with lose water splashing about. Sure it cost time and money, being retired, I have lots of both. I know the water going back into the tank is clean. Bucket water is good for toilets. The water is much more useful to me in the tank!
