humblerb
Feb 20, 2017Explorer
wing_zealot wrote:humblerb wrote:So it had a sign on it, big deal. The tongue weight on a 8000 lbs trailer is only about 1150 lbs. I have seen lots of half tons trucks with payload of 1500 lbs. So the signs don't lie. It doesn't matter if you have a 1/2 ton, 3/4 ton, or 1 ton dually; you must do your own homework.WarPhil wrote:
In my day job I work in a heavily regulated industry. It makes me a rule follower. I'm going to keep my eye open for a lighter trailer. Of course the sales guy said it was no problem. He doesn't care if I kill my family, only if the check clears.
We went to the Houston RV show this past weekend. I can't tell you how many times I heard, "That truck will be fine."
Also, lots of the signs had "Half-Ton Towable" on them.
The dry weights on some of these Half-Ton Towable trailers were in excess of 8,000#.
As you said, the only thing they worry about is if the check clears.
After that, it becomes your problem.
And that is the point. Most newbies don't even know what homework they need to do. And they expect a TT salesman to help them with it. I've yet to meet a TT salesman who even acted like he knew what needed to be done. They are like my wife, who says "Ford says my truck can pull 10,000#, so we just need to stay under 10,000#." I have yet to have a salesman even discuss Payload/Cargo Capacity, how you reduce your cargo capacity by adding "things", like a tool box, a bedliner, some firewood, or heaven forbid, your spouse and/or kids. But, I did hear several times "That truck will be fine". They make this comment without even knowing anything about the truck except it is a Ford Half-ton. "The sign says "Half-ton towable", you have a Half-ton. That truck will be fine."
Yeah, if you do your homework, you will know where you stand.
Those signs are aimed at uninformed (or new) towers. And they are for the amusement of people who know to do their homework.
