MitchF150 wrote:
Sounds like you have a short in the awning wiring? I assume it does this whether you are on just battery or 120v?
And it's just the awning light that blows the fuse either way?
Turn on your inside lights on and no problem?
Turn on your awning light and it blows the fuse?
Or a combo of both?
Not sure how you test that, but you gotta somehow take the internal wiring out of the equation with some test wires to see if it's the fixture or the wiring?
Good luck! Mitch
Yes, it doesn’t matter if I am on battery or 120v. I thought the problem with led connector, so I disconnected the led, turned on the switch and it blow the fuse...
Yes, it's just the awning light that blows the fuse.
No issues with internal lights.
Unfortunately I don’t have such long wires... I thought about it, connect one side to led and another side to the panel.
