FishOnOne
Nov 25, 2013Nomad
Huntindog wrote:
I remember back when Ford fans were anxiously awaiting the debut of the 6.0. The Dmax had been stealing all their thunder and pride...
The 6.0 was to have cast iron heads AND more power than the Dmax....
Nirvana was close at hand...
Well that fizzeled. The replacement 6.4 wasn't much better, as it appeared that Ford gave up on it as soon as it was introduced.
With it's previously stellar reputation in tatters, I really thought that Ford would at the very least stand behind this latest diesel that they themselves designed and produced... Unlike the previous motors, they would have nobody to blame if it flopped.
So I find it really curious that they have taken this anti consumer warranty stance, especially when the competition is taking care of their customers.
The NHSTA numbers show that GM has a higher failure rate than Ford.
But these numbers are skewed some, as Ford doesn't count the ones that they denied warranty on. I suspect that the total failure rate is very close to the same.
I am pretty sure of what GMs motivation is to just handle it in the customers favor. The Dmax has a pretty good reputation over the last 13 years.. Not by any means trouble free, but it has outlasted the Ford offerings. And with being a spectator to Fords missteps, I am sure that they don't want to follow them. And finally there is a certain amount of stigma attached to them because of the govt. bailout.
This failure still seems to be rare. But it is ridiculously expensive if it happens to you.
You say that "GM has a higher failure rate than Ford" and this "higher failure rate" is because Ford didn't include these numbers because those failures weren't covered under warranty! Well does that mean the numbers Ford did report were covered under warranty? I know of several Ford warranty repairs covered under warranty because there was no DEF crystals in the fuel filter, no internal rust in the HPFP, and no gas in the tank. I do know of several HPFP that were not covered due to gas in the fuel tank (which will grenade these pumps)which was the customers or the fuel suppliers fault. Have there been some bad diagnosis by the dealers? Sure there has and there's no disputing that.
Maybe GM because of the prop from the tax payers can look the other way and still cover warranty repairs when there's been gas in the tank or just bad contaminated diesel.
44,056 PostsLatest Activity: May 04, 2014
