Happy_Camper3
May 19, 2016Explorer
93Cobra2771 wrote:
You don't want to eternabond the whole roof. Way to expensive. A quote from the dealer for new membrane over the phone, said $2600,
Those pics are proof that some people should stay away from eternabond. It was either a bad batch, or terrible surface prep. Looking at how sloppy it was applied, I lean toward terrible surface prep.
Pic two, is that a hole in the rubber, or is it a drip of dicor or? A short piece of eternabond over that and it will be fine.
Remove as much of the loose EB and reseal with dicor or more EB.
Or, if that is white peeling off the black rubber of the roof, you may as well plan on having a new roof installed.
The dealer said about $2600 for new membrane, without seeing the camper
I put the EB on myself, 2 years ago. I used the spray that came with it, and wiped it down with a towel. That is all I did.
If I did not prep the surface good enough, can you please tell me how to do it differently ? any help is greatly appreciated..
Also, I am going up to the camper this weekend, is there an easy way to determine if I have water damage ? or what should I look for ?
thanks for all the help so far everyone!
44,056 PostsLatest Activity: Jan 12, 2020
