happybooker1's avatar
happybooker1
How best to fix this?
Last night I went out to the TT I just bought. Moved the shower curtain and found this:
The shower stall assembly is fastened to the TT walls with some kind of round plastic tab. The top of the bottom-most fastener was in the tub and the screw-like shank is still in the wall.
The wall cannot be pushed back into place without some modification. It needs to be shaved off the bottom about 1/8". I don't know how they had it in there to begin with, but it will NOT go flat against the wall.
Here's a couple more pics:
No water damage as we haven't even turned on the shower and from the "button" at the bottom of the tub it must've just happened.
My thoughts are to carefully trim off the bottom edge with w Dremel until the shower wall will go back flush against the trailer wall. Then fasten it back somehow, but how? I will also caulk the edge once I get it back flush.
I need ideas please.
