Devo_the_dog
Feb 01, 2021Explorer
Cummins12V98 wrote:Devo the dog wrote:
Don't buy a 2019 or newer Ram (new or used). The trucks are substandard at zero miles and the only way to expose the problems is by driving them. They can pull heavy trailers, have great exhaust brakes, and are quiet on the highway when towing. But, the rest of the truck has too many problems. Unfortunately, the typical long time dodge/fiat/ram owner only cares if the truck can pull a heavy trailer. So, the manufacture produces a substandard truck knowing they can get away with it.
Maybe you can elaborate. ONLY issue and it's rare is they went to the CP4 injection pump for 2019 and 2020. The 2021 RAM's now have gone back to the CP3 pump.
For those with the 19 and 20's you have a 5 year 100k powertrain. IF something happens it WILL be taken care of.
So please tell us about all these "substandard" issues.
Radio doesn't work properly and even though it's under warranty, Ram hasn't been able to fix it yet. Two issues: 1. It randomly shuts off and reboots. 2. The second issue isn't a big deal but it exists. The service/help button does not connect to Ram when you place a call. But, it will connect to Sirius or Emergency road side service. Ram is aware of this issue and there isn't a fix planned.
AC: If the outside temperature is too low, the AC will not turn on, even if you switch it to manual, turn up the fan, ect. This is a separate issue from the lack of performance from the AC due to no diverter valve.
Transmission: While pulling grades, the transmission will momentarily attempt to downshift and then stay in gear. Consequently, there is a bucking. Initially, it happened once per trip. Little by little, it turned into happening on every grade.
Body mount: Thump/clunk when front suspension (either side) approaches full droop.
Surging. This is an odd one. After I brought it to the dealer for the 1st recall, they did an emissions update and there wasn't surging. Once we moved to a colder climate, the surging started and it's very noticeable.
Check engine light: Latest issue. Don't know what the issue is yet.
I'm bringing it to the dealer again to address recall #2 and the other problems above, again. Will the warranty help? A warranty isn't helpful if you take it to the dealer and the result is: Don't know how to fix it yet. But, the problem is in the system. This is the reason why I say it's substandard. If the problem exists, the dealer knows it, but the manufacture doesn't have a fix yet, it's substandard.
BTW, you may have noticed that I didn't address the CP4.x pump issue. It hasn't failed so I can't comment on it. All I have mentioned are the problems that Ram hasn't been able to fix yet.
This is the first Chrysler/Ram/Dodge/Fiat/Peugeot we have ever owned. We have never had this many problems owning any other car from any other manufacture. Ever. LOL.
The truck is great pulling loads. It has great engine braking. And, it's quiet. But taking it to a dealer to fix something over and over and over, plus the recalls, is a bit of a hassle. Maybe this is just normal for Chrysler/Ram/Dodge/Fiat/Peugeot owners and that would explain why Chrysler/Ram/Dodge/Fiat/Peugeot is so far behind on everything other than the engine. Maybe the longitime owners don't care, or understand, that a truck is more than just an engine that can pull a heavy trailer. So, the manufacture gets away with producing a substandard truck.
