blt2ski
Feb 06, 2021Moderator
Cummins12V98 wrote:Devo the dog wrote:Cummins12V98 wrote:
"I think your assumptions that those issues are widespread throughout Ram trucks are a bit grandiose."
Let me use one of the engineering and manufacturing problems as an example:
The AC.
There is a TSB to replace the AC unit because the Peugeot was too stupid to copy the design of every other auto manufacture that exists on the planet.
The fix is to remove the dashboard, which means remove the trim, to replace the entire AC unit.
Why? Ram didn't include a diverter valve on the heater hose inlet.
Seriously? Even my wife understand how stupid this is.
So, if you do a simple Ram Forum search, the easiest way for a 2019 Ram owner to improve the AC performance to install a shut off valve on the heater hose inlet. If you shut off hot water to the heater core, it'll improve the AC performance, which is why EVERY other manufacture on the planet has been doing this for 20+ years. Ram didn't. LOL.
So, they now have a TSB to replace the AC unit behind the dash.
Whoops.
Why didn't Ram just copy what every other Manufacture has done for decades by Including a diverter valve that shuts off hot water to the heater core when you want Max AC?
Because too many owners will accept it, and defend it.
NICE you took someone else's quote and put my name with it.
jshupe is who said "I think your assumptions that those issues are widespread throughout Ram trucks are a bit grandiose."
Sounds like you need to Lemon Law your truck you hate so much.
Ron,
Took me bit to find, but Devo's quote post is correct to some degree! You quoted jshupe, but did not put his quote as a blatant quote of him in your post. You just used quotation marks.
So with this in mind, would you two calm yourselves down a notch or two.
thank you
Marty
