MURPHY55347
Aug 24, 2017Explorer
Batteries are connected in parallel so you only need to disconnect the one negative cable that goes to chassis ground. I use a disconnect switch like this. You just partially unscrew the green knob and it disconnects the battery.
https://www.zoro.com/battery-doctor-battery-disconnect-switch-negative-12v-20308/i/G3024804/
