cannesdoExplorerAug 24, 2017How do disconnect battery cable(s) at airport...I'll be gone for five days and for some reason the charge in my truck batteries start getting pretty low by the 3rd day if it's not been driven. I have an Edge unit which I only use for the gauges bu...Show More
Grit_dogNavigator IIIAug 24, 2017OP, if you're unsure how to disconnect and re connect your batteries, do a test run before you get there....
Related ContentBattery Disconnect ConfusionBattery disconnectTrailer Brakes Disconnected messageBattery Disconnect... What does it disconnect??Mid 90's F53 Tranny Shift Cable (update)
