cannesdo
Aug 24, 2017Explorer
Durb wrote:
My Edge CTS will sometimes have a scenario where the screen is black but the screen is on which can be determined when it is dark. I find this happens when I start the engine but shut it off before before the gauges can load. Upon restart the gauges will refuse to load until I hit menu twice. I am in the habit now of letting the truck run long enough to load the gauges before shutting down. If you think the Edge is your drain culprit it is easy enough to unplug it from the OBD port for extended non use.
OBD port? Is that the plug behind the screen?
