Old-Biscuit
Sep 01, 2020Explorer III
Racin' Jason wrote:
Thanks for the info guys! It's an Atwood 6 Gallon Gas / Electric Water Heater GC6AA-10E.
10E version uses COMMON 12VDC to BOTH on/off switches then to circuit board.
Circuit board then allows DC to either ECO & Gas Valve for propane operation
OR to the DC Relay then allows 120VAC to the Element
SO.........
Have to have 12VDC Switches for GAS/Electric
12VDC from switches to circuit board (White wire/electric---Orange wire/propane
120VAC from a 15A circuit breaker to the AC side of that DC Relay
Yellow wire from circuit board goes to the DC Relay which is inside the cover on backside of WH TANK where element is
Here is info on 'conversion' see has 23, 24, 25
Atwood Water Heater Service Manual
Here is a 'color' version of wiring diagram
Here is wiring for switches
44,066 PostsLatest Activity: Oct 04, 2013
