ticki2
Mar 05, 2015Explorer
sleepy wrote:
I managed to get accurate measurements for the propane compartment today:
25.5" tall
25.5" deep
12.25" wide
The width might be a problem as far as using the ASME tank with the side mounted valve, gauge, etc... especially if they are mounted on the side of a 12" diameter tank.
I need to actually see the tanks that I'm interested in.... to get accurate measurements.
I don't see any advantage to using the 30# horizontal DOT propane tanks that must be filled in a verticle position.
Thanks for the additional input...
Chet
It looks like your propane compartment is going to be problematic . Even if they fit I am not sure that being on a slide would qualify as being a fixed tank . I am not familiar with your camper as far as layout . Would it be possible to rebuild the compartment so the tank or tanks where facing you broadside when you open the door ? It may be too much work .
Here is another company that makes all kinds of tanks , including fuel cells for propane vehicles .
http://www.worthingtonindustries.com/Home
44,056 PostsLatest Activity: Jan 12, 2020
