pjay9
Mar 14, 2015Explorer
stickyeye wrote:
Why can't you just leave your tanks in place and use something like this so they can attach their fill hose with enough room. It looks like it also extends the bleeder valve - Filling extension
You would still have to remove and reconnect the regulator each time but no more heavy lifting, they can fill it in place. If that won't work they say they can make custom adapters. Good Luck
Sticky
Right off, this seems to be a solution! You'd need two tank releif/fill bleed hoses, even if you switched filler from tank to tank (what a pain). SO get two of these systems, have a welding supply house build you a "y" throw valve for 'fill and use' then you wouldn't have to undue anything...how complicated can we make it!
44,027 PostsLatest Activity: Mar 05, 2025
