westend
Aug 16, 2014Explorer
Here's what I did to mount a 32" LED/LCD screen on a wood stud wall: Mounted articulating arm with tilt onto a 5/8" piece of plywood that spans three studs (approx 32"). The mount was through bolted with 1/4"-20 bolts to the plywood (I cut recesses in the back of the plywood so that the bolt head was even with the back surface).
I then attached the plywood backer board with mount onto the wall. I used glue and put two --2" --#12 screws into each stud. You can skip the glue if you want to remove the mounting board later.
The final step is bolting the arm mount onto the screen.
Of course, the mounting arm isn't going anywhere and the mount I used folds against the wall when in transport mode. I haven't used a strap to hold it in place (it doesn't move) but I may add that if I'm planning on rough roads.
Inland TV wall mount
