Mtrusty's avatar
Mtrusty
How do I remove round AC Ceiling vent?
Hi! Just got a 2020 Sporttrek 312vrk Travel Trailer. Turned on AC in bedroom and one of the round vents is rattling up inside. Sounds like something must be up there. My problem is I can’t figure out how to pop it off. It has the center part that swivels. I didn’t know if I popped off that part or the entire thing. There are no visible screws. Please let me know if you know!
  • There should be a ring around the grill . Pop it off and it will expose two screws to remove the grill itself.
  • Do you know if I should wedge the screwdriver between the ceiling and the plastic or in that part between the plastic base and the part that rotates? I know I should work my way around. It does feel like your breaking it for sure!
  • Sounds like the ones I have and it will snap out with a flat screwdriver. Be careful not to break it.
