Mote
Apr 24, 2014Explorer
JumboJet wrote:Mote wrote:JumboJet wrote:
Be prepared for an "eye opener" if you have soft wood on the front around the window. I have rebuilt two TCs that had front windows with soft wood. One was a 2000 1030 and the other a 2001 820.
When rebuiding those did you peel back the siding from the top down on the outside to replace wood ?
Yes.
The rebuild of the 1030 required replacement of all the nose wood and even 2' of the overhang floor.
With the 1030 and 820, we did not use the front window and opted for a solid front.
JumboJet, Are you saying you did not reuse the front window? I assume you had to buy some metal (or fiberglass) to fill the hole. Where were you able to buy that ? Mine is metal.
44,066 PostsLatest Activity: Jul 25, 2018
