bighatnohorse
Oct 07, 2018Explorer II
presh223 wrote:
Hi all,
. . . I am confident it isn't a result of prolonged water intrusion because it was always covered.
. . . Where so I purchase the filon material, and is there a cheaper alternative?
. . .Should I cut a new seam or put on a front sheet to the base of the camper?
1) Heat is the solvent for adhesive. If your camper was stored under tarps in the desert heat of Eastern Washington then maybe the delam is not moisture related.
2) Depending on where you live, Filon could be sourced from RV repair shops. I could get it from Southend RV Repair in Lakewood.
3) I don't know.
44,066 PostsLatest Activity: Mar 14, 2015
