Lyrikz
Feb 26, 2014Explorer
JIMNLIN wrote:Me Again wrote:JIMNLIN wrote:
Loads placed on the trucks axles is measured at the tires and ground interface and includes axles/wheels/tires/etc.
Just for example.... Your 3500 SRW Dodge has a 6500 RAWR and many unladin rear axles weigh in the 2900-3000 lb range which leaves around 3500-3600 lbs for a payload.
When you have your trucks axle weighed separately keep a copy of the scale ticket in the truck for future reference.
Jimnlin, what tires came OEM on your truck. I recall that in 2003 they switched to 17" rims and LT245/70R17 or LT265/70R17 rated at 3000 or 3195. Neither of those add up to 6500 RAWR??? I kind of remember it was the 245 and the axle rating went down for 6084 to 6000 in 2003. But I could be all wet!
Chris
My '03 2500 has a 6000 RAWR 11.5" AAM and came with optional aluminum wheels and LT265/70-17 E.
The previous '02 2nd gen trucks had a 6084 RAWR Dana 70 and had a 6084 RAWR with 16" LT E.
Some 3500 SRW Dodges came with a 6200 RAWR and later a 6500 RAWR but I have no idea what size tires were used with the 6500 RAWR axle.
The OP has no wheel or tire worries but may need more rear spring help depending on how much payload he needs.
The previous owner of my truck installed a helper leaf and a set of timbrens.
i put a ton of weight in it yesterday... I have pics... It drove like a dream.... Here are the pics. I dont have my 19.5s mounted yet, doing that before this weekend when i pick up my trailer
Before weight added
After weight added
44,066 PostsLatest Activity: Jul 25, 2018
