- harmanrkExplorerSince everyone has beat that answer to death. I'll throw this one out:
Start the engine and let the alternator(s) do its job. Not only will this charge the batteries, but it will circulate the fluids as well. - wilber1ExplorerI've always connected my charger to the positive on one battery and the negative to a chassis ground. Been doing it for years with no issues.
- LwiddisExplorer II18F in Four Corners overnight. Get those batts charged up!
- LwiddisExplorer IIIs this covered in your Ford Owner’s manual?
- Me_AgainExplorer III
pianotuna wrote:
If you wish to be totally picky, connect the positive clamp on one battery and the negative clamp on the other battery.
The second cable connected(the negative) should be connected to a bolt on the engine away from the battery(ies) that might be gassing, and cause a battery explosion. Also that is the first cable you disconnect. Chris - pianotunaNomad IIIIf you wish to be totally picky, connect the positive clamp on one battery and the negative clamp on the other battery.
- 2oldmanExplorer IIHooking up one will take care of both. If you truly want to charge each separately you'd have to disconnect the correct wire. Of course, I'm assuming that.
44,028 PostsLatest Activity: Dec 10, 2013
