- harmanrkExplorerSince everyone has beat that answer to death. I'll throw this one out:
Start the engine and let the alternator(s) do its job. Not only will this charge the batteries, but it will circulate the fluids as well. - wilber1ExplorerI've always connected my charger to the positive on one battery and the negative to a chassis ground. Been doing it for years with no issues.
- LwiddisNomad18F in Four Corners overnight. Get those batts charged up!
- LwiddisNomadIs this covered in your Ford Owner’s manual?
- Me_AgainExplorer III
pianotuna wrote:
If you wish to be totally picky, connect the positive clamp on one battery and the negative clamp on the other battery.
The second cable connected(the negative) should be connected to a bolt on the engine away from the battery(ies) that might be gassing, and cause a battery explosion. Also that is the first cable you disconnect. Chris - pianotunaNomad IIIIf you wish to be totally picky, connect the positive clamp on one battery and the negative clamp on the other battery.
- 2oldmanExplorer IIHooking up one will take care of both. If you truly want to charge each separately you'd have to disconnect the correct wire. Of course, I'm assuming that.
