ib516 wrote:
Perrysburg Dodgeboy wrote:
Me Again wrote:
Young girl that died did NOT have her seat beat on! Chris
Yep no seat belt thrown from the truck and most likely run over be the Mazda. My son now has a plate in his right arm because he didn't have a seat belt on. The driver lost control hit the center barrier and the car rolled on its top and slid over 200 feet. None of the four passengers were seat belted. Luckily Jake was the only one injured.
Seat belts save lives by keeping you in the vehicle and holding you in place via the pretensioners (sp) to keep you further away from the airbags.
Note, the airbags will not deploy if your seat belt is not buckled! Also the bags won't deploy if the pretensioners are not working.
Don
The airbags do work if you're not bucked, but the threshold and speed at which they deploy changes. It will also change based on the position of the seat (forward in it's track or rearward) indicating a shorter or taller driver.
In the end, her life would likely have been spared if she was belted in. Head trauma or internal bleeding are the two biggest causes of fatalities in unrestrained passengers.
The smaller car flipped the truck likely due to:
- Truck's higher CG
- Collision impact angles (side impact)
- Fact that the car is so much lower it acted like a wedge
- The broken wheel is on the impact side, not the "dig in" side
Total agreement. Airbags most definitely deploy even if occupant is not buckled. I travel a lot of miles often late at night and have unfortunately come up on a couple fatal accidents where the driver was ejected. In every instance the airbags were all deployed.
