JIMNLIN
Feb 18, 2022Explorer III
Rscconrad wrote:Not much different than a F350 with the 6.7 diesel.
I know I can research it but I also know you guys can answer in a heartbeat. I’m stuck on 7.3’s. Still rolling with my 97.
As others say Fords F350 srw gives you a 7230 rawr which will be carrying most if not all of the truck campers weight.
Rear axles on these newer gen srw trucks have been weighing in the 3300-3400 lbs range leaving around 3800 lbs on the rear axle.
A 4600 lb payload in the bed will blow the hell out of any brand one ton srw crew cab 7000-7230 rawr numbers.
You can always upgrade to 19.5" tires/wheels and air bags for a 4xxx lb truck camper.
