devildog1971
Dec 06, 2013Explorer II
If your fridge is in your slide you need to put that bubble level in the fridge especially I found out the hard way if your slide ever creeps in a little the fridge will be way out of level because the last little bit the slide goes out it pushes the top more than bottom that is so water will run out cost me a fridge rebuild luckily I found a shop that replaces the back side. the factory put a brake on my slide and told me all slides especially ones with fridge in slide and the slide is electric (12 volt) they need a brake installed it also stops a slide from creeping out when closed I think the refers have ammonia in them but if bouncing will help with cholesterol I will try bouncing a lot
