billtex
Dec 07, 2013Explorer II
devildog1971 wrote:
If your fridge is in your slide you need to put that bubble level in the fridge especially I found out the hard way if your slide ever creeps in a little the fridge will be way out of level because the last little bit the slide goes out it pushes the top more than bottom that is so water will run out cost me a fridge rebuild luckily I found a shop that replaces the back side. the factory put a brake on my slide and told me all slides especially ones with fridge in slide and the slide is electric (12 volt) they need a brake installed it also stops a slide from creeping out when closed I think the refers have ammonia in them but if bouncing will help with cholesterol I will try bouncing a lot
Agreed...that is one reason we chose a camper that did NOT have fridge in the slide...that and the stress fractures that can happen with electric and propane supply lines going in/out...
Always a good idea to level to your fridge as that is the most critical component; level to the fridge while on your jacks, stick the bubble levels on front/side then you are all set!
We don't fuss a lot about level...if within 2" on the bubbles, and head is up for sleeping...we are all set.
Replaced a fridge once on our Airstream...$1600...will try to avoid that again.
BTW; flipping it around did NOT help.
Bill
