Eyeball level has always worked for me - just get some distance between you and the TC on all sides and you'll know it when you see it.
bikerdib wrote:
I thought about doing something similar with the wood blocks. Great idea using the carriage bolts as dowels. I'd cut more of an angle though to help climbing on. Home made wood blocks will be more durable and much cheaper but a little heavier. I really need to build a front receiver hitch so I can put one of the carriers on the front of the truck.
I have used wood blocks for years, and after every trip I promise myself I will finally break down and go buy the plastic variety. I end up having to use duct tape on the majority of the wood blocks (I usually use 2x8 scraps from around the house) to keep them from splitting.
Supporting the weight of a fully loaded truck on uneven/rocky ground is usually too much for modern "crap" lumber. Plastic is forever, and the ones made specifically for the purpose of leveling fit together like LEGOs.
One of these days I'm gonna get to the RV store......
RichieC wrote:
The plastic leveling block got big gravel wedged into their waffle shape bottoms and split.
I'm currently using wood blocking.
Funny, I just read this post - now what am I gonna do? (with my penchant for procrastination I'll probably keep using the wooden blocks and duct tape!)
