Bedlam
Aug 24, 2013Moderator
The springs will sag and not return to the original arc eventually if loaded or worked. The flexing back and forth will weaken the temper over time. I did not notice a change in ride height until I installed my lower StableLoads. I had to jack up the rear of the truck to get enough space to insert them between the spring pack and lower overload spring.
44,056 PostsLatest Activity: May 04, 2014
