pianotuna
Apr 03, 2021Nomad III
Hi,
You have correctly identified voltage drop as a problem. #10 wire may not be enough to solve this issue.
On 30 amps, it is not advised to run the air conditioner and microwave at the same time.
The best solution may be an autoformer. See my signature for the one I use. If you have a friend who travels to Mexico--they are an off the shelf item.
