kerrlakeRoo
May 26, 2017Explorer
"Full charge" is a long slow process. Using the small genny your talking about to charge will likely work, but it will get you enough to keep you going, but understand that a genny that small can not do anything else but run the charger. To put this in perspective for you, the size genny your looking at cannot run a normal household coffeemaker. Most of them are around 900 watts.
