SoundGuy
May 27, 2017Explorer
Dirtpig wrote:
I think you should get 2 new group 31 batteries or 2 6volts and replace your old probably worn out/abused battery. And go for something like this for charging instead of a 45watt panel Renogy 100watt suitcase solar
We camp as does the OP, most times on electric sites, but seem to lose power frequently enough each season that I added a 1000 watt PSW inverter to our trailer so we could still use our coffee maker, toaster, a couple of fans, etc. My single G27 is sufficient for most but does struggle a bit with the toaster load so I cut up an old 4 gauge booster cable set, wired it directly to the truck's battery, and (with the truck running) use it to load support the G27 when it's under heavy load. Without it the toaster load would drop supply voltage well into the 11s, with load support voltage drop is minimal, a non-issue. :B
For periodic use load support works just fine and in emergency cases could be used to push just enough back into the trailer battery to keep it going a little bit longer. However, if we intended to actually dry camp any more frequently I'd choose Dirtpig's option - upgrade to 2 G31s in parallel or 2 GC-2s in series, choice depending on what would fit best on the trailer tongue - and invest in a folding portable 100 watt suitcase solar panel that can be set on the campsite to avoid shade and be moved during the day to follow the sun.
Obviously a genset offers the assurance of effective recharging during cloudy conditions but there's no getting away from related issues - noise, fumes, the need to carry gas, the need to heft it in & out of the truck, storage & maintenance when it's not in use, concern over theft, etc. I've owned 2 Honda EU2000i gensets and in time became so fed up with all these issues I more often than not would leave them home in the workshop. The final straw came in the fall of 2015 when an unexpected freak snowstorm knocked out campground power for almost the entire weekend, and where was my EU2000i? ... back home in the workshop! :S
Bottom line - either genset or solar can be an effective solution for many but based on my genset experience a portable folding suitcase style solar panel sure seems to be a solution I'd be much more likely to always have on hand when we're camping and actually use. :)
