SoundGuy
May 27, 2017Explorer
rbpru wrote:
At this point I think I will reduce the phantom loads by turning off the antenna booster and disconnecting the radio/CD player.
Presumably you've already switched all your incandescent bulbs to LEDs but do you remember to disable your fridge climate control heater when running on battery power? If your particular fridge isn't equipped with such a switch it's good idea to add one yourself as you're otherwise unnecessarily drawing down your battery reserve. ;)
My climate control switch mod is detailed here.
