d3500ram
Jun 15, 2015Explorer III
coolmom42 wrote:
Always leave the water pump off when not in the camper for more than a few minutes. If there is a leak, you should notice it while you are there...
Boy and how one will notice a leak!!! I performed some plumbing modification upgrades to my NorthStar a few years back. When leak testing after the work was done I found out the hard way that one connection was not up to snuff. The time it took to turn on/ walk back to visualize/ RUN back to turn off the spigot was "only" about 6-8 seconds but it was not a drip type leak! I re-checked all of the remaining connections after seeing what one decent leak could do in a short time. It took a couple of bath towels to soak it up and wring out a few times.
Lessons learned: do anything to keep pressure off the lines when not needed; check the integrity of the camper plumbing connections at least once a year and pressure up before leaving on each and every outing (easier to make any last minute repairs whilst still at home.
coolmom42 wrote:
...And if you are hooked to city water---turn it off at the spigot when you leave.
Ditto on that.
44,056 PostsLatest Activity: Nov 19, 2013
