tedp's avatar
tedp
How much does weight matter
We currently have a 2006 Jayco 25' TT weighing in at about 5200 dry. We tow with a Nissan Titan. The truck handles the trailer fine but it is now just the 2 of us and we were looking to downsize. Another reason for us to go to a smaller trailer is I thought it would be easy to tow a trailer that weighs in at around 3,500 lbs. Maybe even be able to just set the cruise on most fairly level payment and go. Does the lesser weight of a 20' trailer make that much of a difference? We are currently looking at a 2011 Aerolite 195QB. Thanks for the help!
  • That's also a consideration of the newer trailer, It is much more aerodynamic.
  • SolidAxleDurango wrote:
    Francesca Knowles wrote:
    If you're just talking about moving the setup/fuel economy etc.:
    Weight makes a difference at starting/low speeds and on hills, both up and down. At highway speeds, frontal area/wind resistance is more of a governing factor than a thousand pounds or so of weight.
    ^^^ agree very much so... Over 50 mph, wind resistance is the largest factor.
    Very true.......
    BUT that Nissan will have a much easier time getting the lighter/small trailer up to 50 mph and maintaining speed.
  • If you're just talking about moving the setup/fuel economy etc.:
    Weight makes a difference at starting/low speeds and on hills, both up and down. Above fifty mph or so, frontal area/wind resistance (drag) is more of a governing factor than a thousand pounds or so of weight.
