rhagfo
Apr 14, 2017Explorer III
Cameo Phil wrote:
New injectors for a 2002 LB7 engine is about $2300 dollars (parts only) plus $1200 for the core charge which is refundable. Remanufactured injectors run about $1600 dollars (parts only) plus the core charge. The rest of the $6000 would be for installation. Since you need to pull the rocker covers on a LB7 the rest of the dollars ($3700) is labor. Get a detailed listing of the charges and make a decision to see if the charges are in line with this. Bottom line, its probably not too far off on price.
:h
Wow, figuring $100 an hour for labor, 37 hours to replace eight injectors?
One more reason to Keep the 2001 Cummins could likely replace in one day myself, the injectors were only $400 for all six new RV 275 Bosch.
44,068 PostsLatest Activity: Jun 10, 2026
