Grit_dog
Apr 15, 2017Trailblazer
There are basically 3 types of injectors available.
New injectors which can be had for around $300/ea
Reman injectors which can be a safe alternative depending on the source, which are old injector bodies completely rebuilt with all new components.
Re furbished injectors which may simply be old injectors that still operate within spec or repaired to the least extent to get them in spec. Avoid these for the most part unless you like wrenching.
Anything but new and the buyer needs to do careful research.
$6k for new injectors sounds high by a grand or so, if talking LB7, but depends what's re used or if all new injector lines etc are installed.
Expensive proposition either way and I would shop around and not discount local hi perf diesel shops as these guys generally are enthusiasts that have done more than your avg dealer tech and have reduced overheads.
44,068 PostsLatest Activity: Jun 17, 2026
