blt2ski
May 21, 2013Moderator
Sheet..... I used to pull a 3K trailer with a 105hp 292I6! I pull a 12K trailer with a 175/335 diesel, no turbo to boot!
Issue is NOT the motor! it is the cooling system of the tow rig. See if you can fix that frankly! I used to pull my 24' 6500 lb TT at 15K total with a 185HP motor too! granted it had 385 lbs of torque!
I would also not look at a nisheet either! I would fix what you have! you have more than enough motor!
Marty
Marty
