- llowllmsExplorerIf you know the extent of the damage it may be able to be repaired with a fiberglass patch. The prep work would be the key.
- welovecamping12ExplorerMy dad thinks that we should not get a trailer that has had a tire hit the bottom of it. He's been RVing for years and a couple of years a ago they had a blow out and it ruined the bottom of their trailer. They had it fixed but the trailer was never the same. The slide kept messing up and some other things. My dad said If in fact it was just the fresh water tank and that's it that was damaged it wouldn't be an issue other than getting it fixed. so I think I will just end up getting the jayco kiwi.
- midnightsadieExplorer IIthe labor is going to be high a lot of belly work. and fitings to match up.
- darsbenExplorer IIfind a tank here that would fit
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1311.R1.TR2.TRC0.A0.H0.Xrv+fresh+water+tank.TRS0&_nkw=rv+fresh+water+tank&_sacat=0
44,066 PostsLatest Activity: May 13, 2026
